MitchF150
Jan 24, 2022Nomad
I went with a phone app to monitor my trucks vitals. It's called Torque Pro and as far as I know, only works on Android phones.. It connects to different brands of ODB2 connectors..
The "gauges" in my 13 F150 don't move after they reach their 'normal' position. The only time they will actually move is when you have reached some very high temp level or if the oil pressure goes < 5psi.
I paid $5 to get the full version Torque Pro app. I think I paid around $25 for the BAFX ODB2 adapter that links to the TP app on the phone.
You can setup a lot of "PID" data that monitors actual temps and a bunch of other stuff you will never really care about..
Unfortunately, it DOES NOT monitor oil PSI or TEMP.. That might just be that my ODB2 does not have that info in the ECU for 2013?
Anyway, has worked for me since around 2018 and really helped me adjust my driving habits and how I let the rig tow in various conditions.
Good luck! Mitch
Good luck! Mitch
38,782 PostsLatest Activity: Sep 02, 2026
