Newbiecampers
Jun 05, 2019Explorer
AGM Battery alternator charging/ possible alternator issue
Hi all,
Searched for some time now for an answer to this but am not coming up with exactly what I was looking for. Plus most battery/battery charging threads end up being 14 pages long with details that start to make my eyes water.
When starting to use our Class C this spring I noticed our starting battery (stock flooded) had leaked a little acid. Had never done this before. Did not think much of it at first. Also noticed our "2nd isolated" chassis battery (on frame rail under coach) may have leaked a little as well. House batteries as well showed a little leaking and corrosion on posts. More than I had seen in the past.
Took our first short trip. After about 2 hours of driving on the way back home started to smell what I characterized as "battery charging" smell (venting). House batteries are under steps and inside of house.
Next morning, went out to check house batteries and saw much more leaking/corrosion. After moving RV a day or two later saw acid stain on driveway as well. Removed house batteries and had a lot of clean up/repainting to do in compartment.
Mulling over the situation, thought about the only common connection between all 4 batteries is the alternator. It is a 220 amp alternator that is part of the "RV package" on the chevy 4500 chassis. I checked the alternator voltage output at the starting battery and it was 15.3 volts right after start. I let it run for 1 hour and 20 minutes, checking around every 10 minutes, and it never went below 15.07-15.1, and that included around a 10 mile drive. Prior to starting the engine the starting battery voltage was 12.9 and the 2nd battery was 13.05. Looking back at some old notes, I saw that previous voltage had also been 15+ after start. House batteries were not hooked up/were out of the camper.
The questions:
-Want to replace my toasted house batteries with AGM. With the batteries being within the envelope of the house I don't want any further chance of fumes coming in. Especially with the kids. Should I be concerned with the alternator constantly charging at 15 volts? I have yet to see it go under that. We often drive for 8+ hours in a day. Do I need to put something/some device between the alternator and house batteries to stop/control the charging? I am also going to replace the wfco converter with a progressive dynamics, but we do alot of "boondocking" and don't do alot of converter charging anyway.
-Does it sound normal that the alternator output never seems to go below 15.07 volts, especially considering the batteries were almost full charge anyway? I am wondering if this alternator has a problem with voltage regulation and has been cooking the batteries, leading to the failure of the house batteries after roughly 1 year 7 months. I'm going to talk to a Chevy dealer about it/have them check it out before I put the new house batteries in as the alternator would still be under warranty.
-Any recommendations on some group 24 size AGM Deep cycle batts that don't break the bank?
The questions:
