tropical36
Jul 09, 2019Explorer II
KevinandHarvey wrote:
We are new Class A owners. Was running our furnace and coffee maker and our Pure Sine Inverter warning buzzer sounded a intermittent beep, then constant then shut down. Was I over loading the inverter? Thank you!
What size inverter? A 1K should run most any coffee maker.
A propane furnace fan, is 12dc and runs directly off of the batteries.
My guess is for low batteries and for whatever reason, if your inverter is of adequate size.
I'm assuming your converter charger is in combo with your inverter and either way, the battery charging function should be checked out firstly.
Using a voltmeter on the batteries and switching the charger off and on should show a difference. Also with the engine's alternator running.
If your batteries are shot, then they're not going to hold a charger, regardless.
