mpierce
May 10, 2016Explorer
ricelake922 wrote:
Thank you. Will definitely check the loose flair nut.
Maybe, but I think much better odds that you have a leak in an application hose to one, or more, or the brake chambers.
Either way, you need to be able to get under safely and blocked. Then, with full pressure, turn engine off, release the parking brake, and have one hold the brake pedal down with another underneath looking for air leaks. There has to be at least one, or more.
