azdryheat
Oct 19, 2018Explorer
Mondooker wrote:Just to be more accurate, it depends on the coach as to the 3 position switch. Some have Off/ON, others have LOW/HIGH, while others have LOW/MED/HIGH.
You guys are correct, air brakes do not turn on and off, they are constantly on with the engine start. Most diesel pushers have a gauge or trouble lights on the dash showing that brakes and airbags are fully aired up.
As for the slowdown you've noticed its your exhaust break or Jake brake that is slowing you down. You should see a three position switch on the dash allowing you to set it to High (maximum of breaking), Low and off.
Most folks leave the exhaust brake on at all times EXCEPT in icy or wet conditions. Especially true if your coach has a tag axle.
38,776 PostsLatest Activity: May 14, 2026
