rhagfo
Oct 20, 2018Explorer III
et2 wrote:Mondooker wrote:
You guys are correct, air brakes do not turn on and off, they are constantly on with the engine start. Most diesel pushers have a gauge or trouble lights on the dash showing that brakes and airbags are fully aired up.
As for the slowdown you've noticed its your exhaust break or Jake brake that is slowing you down. You should see a three position switch on the dash allowing you to set it to High (maximum of breaking), Low and off.
Most folks leave the exhaust brake on at all times EXCEPT in icy or wet conditions. Especially true if your coach has a tag axle.
Not sure what a tag axle benefit the exhaust brake gives vs no tag. The brakes on a tag axle are way more capable of slowing down vs no tag. Actually the exhaust brake on our tag is not as effective as the non tag we had. Probably because it's a lot more weight. I find I use the brakes more.
Getting a little confused here, typicality TAG axles are not driven, so not affected by an exhaust brake function, it only works on driven wheels. Now yes a tag axle will have air brakes on it and will help with braking.
38,776 PostsLatest Activity: May 15, 2026
