J_R2
Jun 24, 2016Explorer
David0725 wrote:Use your onboard. Get a hose, 50', with hookup to coach port, other end with lock on valve stem fitting. Hook up, pump down brakes, watch air gauge, when compressor spits off. You will have what ever your on board air says, is what is in your tire.
J&R I do have a onboard compressor that goes to 120. but I have never tried it because I had a 30gal 135psi and it wouldn't do the job? this one I am looking at has 15.2 CFM 13.SCFM @40PSI AND 10.5 @ 90PSI Not sure what all that means?. 240v 6.5 hp.. 60gal. I didn't think one of them pancakes 150psi would do it because of the tank being so small.
38,769 PostsLatest Activity: Apr 04, 2026
