xctraveler
Jun 26, 2016Explorer
Phew, you guys are running high air pressure in your tires. Having taken 4 corner weights on coach and run the numbers into the Michelin Inflation table for my tires I run 85 front and 95 rear. No problem maintaining those pressures with on board compressor.
May just be that my coach is a lot lighter then yours - actual weight is around 29 - 30k lbs (depends on water and fuel levels more then anything else).
38,769 PostsLatest Activity: Mar 31, 2026
