jkmac408's avatar
jkmac408
air compressors
I was wondering what air compressors some of you are using to air up your motorhome tires. We have a gas MH so no built in air comp.
  • I used to have a Porter Cable 5 gallon pancake compressor, but now I have a Senco 1 gallon compressor. It takes up less space and is MUCH quieter. The down side is it takes a lot longer to air up a tire if there is a significant loss of pressure. I very seldom need to add air while out on the road. I always check the tires at home before I leave and it usually takes a couple months to drop 1 PSI according to the TPMS.
  • gsf35099 wrote:
    I carry a Pancake 5 gallon 150 psi compressor with me. I've got the onboard, but it takes to long.
    X2 You can pick one up at Lowe's.
  • I carry a Pancake 5 gallon 150 psi compressor with me. I've got the onboard, but it takes to long.
