5thhand wrote:
Probably need smaller compressor to haul with. Concerned whether it can top off 90-100 PSI,
Also looking for moderately priced garage version.
ViAir makes some good 12V compressors, but they're expensive, and there's a limit to how fast an affordable 12V compressor will be - a 1 HP motor at 12V will need over 60A of current.
You can pick up a pretty big compressor at
Harbor Freight for a few hundred dollars -- like one with a 21 gallon tank @ 175psi.It's going to take a little while to fill that tank, but once you do, inflations will be quick.
I only fill my tires to 85psi so bought a relatively small
Bostitch compressor - it's small enough that I can put it in the back trunk of the RV, but is pretty fast at filling tires. It needs 120VAC power so I need to run the generator or have shore power to use it. It's oil free, so I also use it to blow out the water lines at the end of the season.
