DANO2014 wrote:
Appreciate the Info but my problem is locating the low side of the cooling unit. I don't think I have a leak because it has been putting out cool air for quite some time and by adding coolant or connecting to the low side the gauge should give me an indication if it is low or not?
Thanks again, I know just enough about A/C's, I could be dangerous!!
Then you should know that Freon doen't wear out. You ether have a leak or your condenser is dirty or your ac coil is icing.
find someone you trust and have them look at it.
