DANO2014 wrote:
Appreciate the Info but my problem is locating the low side of the cooling unit. I don't think I have a leak because it has been putting out cool air for quite some time and by adding coolant or connecting to the low side the gauge should give me an indication if it is low or not?
Thanks again, I know just enough about A/C's, I could be dangerous!!
If it is not leaking but cooling has dropped off, where has the ability to cool gone? If it is not leaking, why is it necessary to locate the low pressure valve and add more R134a? That will only cause problems if not needed. Like someone else said, "find and fix the leak".
