10forty2's avatar
10forty2
Air Condition Unit
15K rooftop Unit. Went on a overnight concert trip this weekend and camped in a grass parking lot. It was exceptionally hot/humid for this time of year and we were running both A/C units as hard as they could go....set at 64 to get the coach to cool down. The one in front is the 15K unit...the bedroom is a 13.5K unit. Bedroom unit was cooling fine with plenty of air coming through the ceiling ducts. BUT....the front unit was barely moving air through SOME of the ceiling ducts with fan set on high. What air was moving was fairly cool feeling, but not what it has been in the past, and again, very little air movement even though we could hear the fan running and it was set on high. Is something maybe blocking the ducts or did it freeze up from all the humidity? I've never tried to pull the cover on the unit and see what's in there. I'll go back out today and see it it seems to be any better after being off for a couple of days.
  • It sounds like it just iced up, which could be from a low Freon level or from exceptionally high humidity. Of course your rear AC operated fine in the same humidity so I am guessing that there is probably a problem with your front unit that caused it to ice up. You may want to pull the top cover and clean everything and remove the ceiling cover and make sure that all of the duct connections are sealed.
