bsheet2 wrote:
dougrainer wrote:
Just for your info. The REAR is a 13,500 BTU They do not make a 12,500 BTU. 37 foot units need 2- 15K AC units for Texas heat. That extra 1500 BTU will do wonders in Texas Heat. Doug
Ok, you are correct. 13,500 BTU AC in the back. Actually it does very well in the bedroom even in this heat. The front has a new 15,000 BTU unit that was put in as part of the purchase.
Thanks for info. My take away is that the AC units are doing their job. It is just too dang hot.
Actually the AC did better today. I started everything early in the morning and we minimized going in and out. It stayed decent in the heat of the afternoon.
I will take some of the good advise in the above posts and try to improve the insulation to keep some the heat out.
Thanks everyone!
In a Motorhome, the REAR AC will perform colder than the front AC, regardless of AC size. The Rear AC turns over less volume of air and will yield colder output, even with a ducted system. Doug
