jamharrison wrote:
Driving during the summer heat yesterday which was about 95 degrees into the sun. The coach was very hot even with running both AC units and the dash running. It was still 85 inside coach, is this normal, the dash has never blown cool air? This is my first DP
My experience is that keeping dash air working correctly is an ongoing problem requiring maintenance every few years.:(
1. Get the dash air repaired, or don't run it as it is contributing to your heat problem. If you don't run it, try to block the air intake so you are not getting hot air bleeding into the coach.
2. If your roof a/c's are producing air 20 degrees below the intake air, that's about right. If not, get them repaired/replaced. They may need a good cleaning.
Assuming that your roof a/c's are working right, you can get a lot of relief for the front of the coach by placing a large fan on the floor midway of the coach with the fan blowing toward the front of the coach. This will push cooler air forward. We do this often, and it really helps.
Fred
