RRodda's avatar
RRodda
air leak problem
Freightliner XL chassis, 2002 Newmar Kountry Star...air leaks down to 0 on the dial in a few hours, yet it was not sitting low when I went to move it. I can hear an air leak underneath in the right front area along with a little noise every 5 seconds or so, sort of like a small squeaky noise.
I assume the air bags are still full since it did not seem to be sitting low.
Tomorrow I will do the soap spray, but and ideas of what I should be looking for?
Ron
  • Several things may be in that area. Check for a solenoid that operates the step cover. It should be on a frame rail on the passenger side in the generator area. Since you already can hear a leak, it should be pretty easy to locate.
    BE CAUTIOUS UNDERNEATH A COACH WITH A KNOWN AIR LEAK !!!! It will fall faster than you can crawl out from underneath.....Dennis
