I have an air leak that I had asked about in a previous post. To follow up would it hurt anything if I charged the air system with an external compressor while I tried to pin down the leak? Thinking I...
But, depending on where in the system you "back feed" it, there are check valves that should keep pressure from going back from that tank toward the dryer and compressor. So, it may not pressurize the leak site.
