Kayteg1 wrote:
I did not like air leveling as even 15 tons coach will move with 100lb person walking around.
And if at any doubt - read the manual.
Too many variations in design to apply procedure from one system to another.
I remember practical advise for tilting jacks to move them to vertical position before dumping the air.
When you set the coach too low before tilting jack, they can hit the ground at angle with bad consequences.
Always check the jacks around before lifting.
Our previous '08 Dynasty had air leveling AND hydraulic level legs. Both had slight movement.... If I didn't know, I couldn't tell which one was being used, they both would move a little when someone walked through.
The new coach is air leveling only. At 55,500 lbs., we also have a little movement.
MM.
