busyguy wrote:
Thanks guys for all the input. My leveling jacks are not connected to the airbag system in any way. If I don'topen the dump valves manually then the airbags never deflate. My dump valves are the kind you turn to open and close. Not like a bleeder valve on the bottom of the tank. Will take a look at an electric valve.
Busyguy
I have NEVER seen a Diesel Air bag system that did NOT deflate when the jacks hit the ground and start to lift the RV. This causes the ride height levers to move and THAT causes the bags to deflate. This does NOT happen on your Harney? I would suspect you have had a faulty system since it was new. There is NO sense in having the air bags stay inflated when you extend and level the RV with leveling jacks. Is there a Harney group or owners group you can contac and ask about this issue? Doug
