timmac
Aug 21, 2015Explorer
7ofus wrote:
I have all 4 bags on my F53 controlled independently from the drivers seat. I think it is less expensive than what you are looking at, and can be changed on the fly. I originally got it because I needed about 1" to clear the tail on my driveway. I just air up the backs and dump the fronts just before I pull in.
I have never experienced the sway you seem to be getting.
Mine are not controlled independently, I can fill both bags in back at same time as well as the front bags and I think this might be my problem is when leaning to one side the air is forced out the bags on the side leaning and into the other side causes it to roll back and forth as they talk about in the video above, I could run all new lines and set it up independently and new gauges and control panel as yours but seems like a lot of work, so thinking maybe the motion control units will do just as good and only take a few minutes to install.
