Harvard wrote:
In my case, I used all available adjustment from my bushings for +CASTER and let the CAMBER fall where it may. In other words the CAMBER setting on the bushings at 0.0 DEGREES while the CASTER setting on the bushings was +2.0 DEGREES. Again, I used Ingalls 594 bushings and only because they were already installed on my unit. Good luck, play safe. :)
Adding to this I should explain my starting point was the result of having an alignment done on the vehicle. Then using that alignment report I was able to reverse engineer using the Ingal 594 cheat sheet. By my acceptance of the resulting CAMBER I was in hindsight relying on having a suspension system not damaged or twisted. Again, in hindsight, if any damage existed it should/would have shown up on the up front alignment. In my case, it was the +2.0 degrees of CASTER added to the (LH)+3.3 and (RH)+3.5 degrees that existed by virtue of not having a bent up or twisted front end.
