tpi wrote:
Harvard on the eccentrics, all I know is they were replaced by Ford with Ford parts in first alignment. Do you think I can achieve my caster goals with Ford parts?
Thanks for feedback on toe-in. Sounds like consensus is a bit less than I originally thought.
If they are "eccentrical" by definition they should allow you to "stir" around the top of the upper ball joint. If you put it all towards +CASTER then the CAMBER will be CENTERED and you will end up with the most +CASTER available and a CAMBER that depends on the deflection of the front springs.
I am not convinced that the secret to having a E350/E450 drive like an SUV is in the CAMBER, my experience strongly suggests it is all about +CASTER. :)
