I'll see what I can do on photo. Looking at my alignment report, it appears they tried really hard (and succeeded) at getting everything exactly in the center of the adjustment range. Today when I was over there and chatting they seemed initially surprised someone would want to intentionally set something at one end of the spec. I explained others had success with these settings. Writer went back in shop and chatted with tech, came back later and said he should be able to accommodate my requests.
Harvard one more question.. I should still respect the slightly higher degree of positive caster on the right side? Right side should have .3 degrees more than left side (or so)? Not just try to pile on as much as possible on both sides..?
