tpi's avatar
tpi
Alignment settings goal review
I'm about to take my 24' E450 class C for it's second wheel alignment armed with more knowledge.
Caster is currently set to 3.9, 4.2 degrees, I'll have it set to maximum achievable up to the specified max.
Tow in is set to zero. I'll request it set to .5 degree towed in.
Camber is currently set to .6 degree. Any suggestions to where this should be? Comments about my other proposed settings welcome.
Weight of rig with normal stuff, full fuel, half propane, empty gray and black, and half fresh water is 11,500 with 3900 on front.
  • In my case, I used all available adjustment from my bushings for +CASTER and let the CAMBER fall where it may. In other words the CAMBER setting on the bushings at 0.0 DEGREES while the CASTER setting on the bushings was +2.0 DEGREES. Again, I used Ingalls 594 bushings and only because they were already installed on my unit. Good luck, play safe. :)
