My 2000 Safari Sahara has a couple of small leaks in the bolts. One on a drain bolt and another one on the bolts on the front. Suggestions? Just try to tighten them up a little?
Whoever serviced the trans last should have changed out the crush washer on te drain bolt (copper or aluminum). As for the other bolt? Remove it. Put some teflon paste AND tape on it. Re-install it.
