Tedtoo's avatar
Tedtoo
Allison will not go in gear
Posting for a friend-she is at a rally that is ending. Original problem was MH would start, but not stay running. Because she had previous problems she disconnected something on engine, then MH would start and run. Seems to go into reverse and move (she cannot back up where she is parked) but when put in drive will not move forward. She has re-connected part she had disconnected. 1996 Monoco Dynasty. I suggested check to see air brake was off, recycle jacks, and check transmission fluid. Coach is running now, but does not move. Any more suggestions? She is 14 miles from nearest small town. Thanks for any help you can offer.
TedToo
  • Has it been parked there a long time? If so then the brakes are probably stuck.
    It can take some major pounding with a mallet to break them free.
  • The Allison transmission defaults to neutral at 11 volts. It could be in the charging system, and a low battery. A quick jumper from the house batteries (if at full charge) to chassis batteries, would discount that issue.
