wolfe10
Jan 19, 2016Explorer
The important thing is to find an alternator AND hook it up properly for how your coach is wired.
All alternators have: B+ lug-- the large-gauge wire for 12 VDC positive.
Some have a ground lug, others ground through the mechanical attachment to the engine.
Some have an external sense terminal/wire-- critical if you have a diode-based battery isolator.
Some have an "ignition hot" excite terminal/wire
So, first step if to verify how your present alternator is wired. Only deviate from that on very sage advice!
