- rgatijnet1Explorer IIIIf you go to AGM batteries, be sure to adjust your inverter/charger to the AGM battery charger setting. My Xantrex inverter/charger has a different setting for AGM batteries than I had with my previous flooded cell batteries.
- wa8yxmExplorer IIIIf you are getting only 4 years going AGM is not going to help. You have a problem.. There are a few things that kill batteries fast.
First: My battery story:
Motor home purchased 2005 (May) Flooded wet cell house batteries and Maintenance Free Chassis battery (Chassis build date Aug 2004) I replaced the Chassis battery I think in December, House in Feburary (Last dec and Feb in both cases) Might as well say this year on both.
AGM's purchased in 2006 put on their own "Loop" (Isolated from flooded wet cells) with Xantrex Prosine 2.0 programmed for AGM.. As they aged I added a couple Group 29's I had that were OLDER than the Motor home.
AGM's replaced in 2011 (With maintence free),, One G-29 junked in 2012, Rest replaced in 2013.
IN short, the AGM's only lasted 5 years,, (Actually they should have been replaced earlier)
UNLESS you are doing a serious electrical upgrade there is no advantage to AGM over Maintenance free save the ability to disregard "This side up" stickers.
Now: your problem
The things that can kill Flooded wet cells include:
Lack of owner inspection and maintenance (letting them dry out), use of NON distilled water (Tap water contains minerals that damage the battery).
And all the things on the list of "Stuff that kills ALL lead acid (And in many cases other types) of battery:
Leaving them "Run down" for extended periods
Winter storage in a "Run Down" condition (Put a battery midner on 'em if you do not have a top rated converter like the Progressive Dynamics Intella power 9200).
Running them down too far too often (more on that in the next "page" (Section).
And finally,,, BAD CONVERTER.. The Magnetek 6300 line is noted for being very slow to recharge (A good thing) but not knowing when to stop (A very bad thing), and it's not the only one that does that. Some converters NEVER fully charge the battery,, Some never stop charging. I only rank the top and bottom ones by name.
Running them down too far:
DEEP CYCLE batteries (like the GC-2 Golf Car battery which is a flooded wet cell) are designed to survive routine discharge to as low as 50% SOC with the occasional "OH $#!t DEEPER discharge (like to the point where lights, won't) Mine were taken down to 10 volts or less at least half a dozen times over 10 years.
Starting batteries ... Well, I would suggest you not run them down that low they like to be near full (Say 80%)
Marine/Deep cycle, are primarily starting batteries,, Try to keep 'em 75 or better
The major differences between the types:
DEEP CYCLE is much more likely to recover from an OPPS level discharge.. But Starting batteries are better are really high discharge rates (Relative to their capacity)
So, how come your DEEP CYCLE house batteries can be used via the AUX/EMERGENCY Start/BOOST button to "Jump start" the engine?
Well, my Chassis battery is I think 78 amp hours, so a 150 amp load (Starter is typically less than that) is, slightly rounded 2x the 20 hour capacity of the battery.
But the house batteries (As delivered) 220 amp hours, So that same load is just over 70% of C/20 capacity.. That's why.. For the Big jars it's a much smaller load. Oh, new house batteries are bigger, 230 amp hour.. I could not lift them off the ground lying on my back (I could the old ones) they have to be lifted in. I did lift the chassis battery. - pianotunaNomad IIIHi,
I'd go for agm and add a solar system, too. - dons2346ExplorerGoing on 11 years with my Lifeline 8D AGMs. Got 2 years out of the original flooded cells
- Teacher_s_PetExplorerJust got less than one year out of a set of DEKA AGM batteries..failed due to "misuse" per manufacturer and distributor. Battery dis-connect turned off and parked in heated storage over winter. No phantom draws only problem was isolation relay wasn't functioning when driving down road, found by my service company. Distributor was backed by factory saying "not their fault" batteries were not fully charged on parking in September...looked like someone stuck a straw in them and sucked the guts out of them. We were on tight schedule and my service company had pulled them for replacement and his guy brought back 2 more with a slight discount and their rejection note. They are buried under the floor and I wanted something I wouldn't have to "water". Got what I wanted we "never had to water them". If we had been notified, would have gotten another brand. Scottiemom was not a happy camper.
The good news is we got the batteries changed in the B+, the dash AC fixed on the Phaeton, Phaeton serviced, valves adjusted and an exhaust pipe replaced for $100 less than the low estimate I had planned to spend on the Phaeton going in. So it's not all bad news. - Bill_SatelliteExplorer IIMy first set of AGM's lasted 10 years and I did not have to even think about them much less do any kind of routine maintenance. I like them as house batteries but I doubt I would pay the extra if they were going to be used as a starting battery.
- Mr_Mark1ExplorerWe suffered through 6 years of our 8 wet cell house batteries (what was I thinking)... and decided to switch to AGM's. Now, I don't have to check water levels or have that corrosion to clean off. And, I save the pain in my back from bending over to put distilled water in the cells (have a bad back).
I would have hated to change perfectly good wet cell batteries for AGM's but now that I have them, I wished I had changed them earlier.
Go with AGM's, you will not regret the additional expense.
MM. - 2oldmanExplorer II
- TucsonJimExplorer III switched from two 12V Flooded batts to two 6V AGM. Now I don't even have to worry about venting.
- sch911ExplorerI would go with AGM batteries. Not sure what a AMG battery is. :)
