joraz
Sep 24, 2013Explorer
Anode Rod for Atwood
I've got a new Atwood 10 gallon water heater in my rig. Someone suggested to me that I add an anode to this tank. I'm looking for opinions on whether this is a good idea. Thanks. jor
Ozlander wrote:TucsonJim wrote:
Suburban water heaters require an anode rod due to their construction (steel tank). Atwood water heaters are aluminum and do not require an anode rod. They typically have a plastic drain plug that can break when the plastic gets old and brittle. I'd suggest you pick up a spare drain plug the next time you're in an RV parts store and carry it as a spare.
What TJ said. That's all you need.
