Mlewin51's avatar
Mlewin51
Another awning issue
I've been racking my brain. I have an 06 Damon diesel pusher and a few days ago the awning would not go down. When I hit retract the motor kicked in but it was already up. Just won't budge going down. I check dometic panel and the wind light was blinking so I figured the wind sensor was bad (which is common), however, now I'm not getting anything. The power to the panel does not exist. So I figured check a fuse. I wish! I can't find the **** fuses anywhere. In the coach or chassis. I checked at the front elec bin (drivers side) and no fuses are blown there. But I yet to find anything labeled awning fuse. Thoughts?!
  • Ok but for my own curiosity where would they hide the awning fuse if it's not labeled anywhere else
  • If the motor kicks in I doubt that it is bad.
    Mine acts the same way when the wind sensor is wet or raining.
    Ok after it dries out.
