drmopar
Jul 21, 2016Explorer
Easy test-get a voltmeter, disconnect positive cable at house battery, and hook one voltmeter lead to the positive house battery, hook the other voltmeter lead to the positive cable you just removed. Before doing this, check battery voltage and record. Once you hook up your meter it will show either full battery voltage or something lower if there is a draw on system. If it shows anything on meter, go to you fuse panel and remove one by one and see if voltage draw goes away. Full battery voltage on meter is easy to trace, lower voltage can be a short, poor ground, and a number of other things.
38,774 PostsLatest Activity: Apr 26, 2026
