Executive45
Jan 28, 2015Explorer III
sealevel ram wrote:
The system worked fine in the past, but became intermittent, and now nothing at all.
This statement indicates a failing control board or a failing ground. Since the ground is the easiest and cheapest fix, I'd start with that. Locate the ground wire and jumper the system with a known good ground. If it lights up as it should, replace the ground. If not, then you'll have to wait on HWH to get back to you. Otherwise you might just be throwing $$ away.....Dennis
