siggyd777
Jan 28, 2015Explorer
On my NEWMAR MH,the leveling works ONLY in the ACC mode. Set the key to ACC,then
take a good look at the HWH control box,there are LED lights inside,check and write down which ones are ON. the box has a plexi glass cover,located in the left front under the hood.Check all the connectors there and the connector to
the touchpad. Then call HWH with your findings,model # or email them.
I had a very good experience with them a few years ago on a 325 system and fixed
the board myself.If you have a multi-meter,check for 12VDC and good grounds.
