But best read the instructions first for Rejex, as it is not easy to properly apply. -
"REJEX APPLICATION
Ideally, RejeX should be applied to a cool, dry, clean surface. When over 85° F, be sure to apply RejeX out of direct sunlight. If the surface is too hot, the coating can cure before it has properly bonded to the surface, so it may not perform up to its potential.
RejeX is wiped on, allowed to dry to a haze for approximately 20 minutes, wiped off, then allowed to cure for 8-12 hours (depending on the humidity; the higher the humidity, the faster the cure). Curing is required to allow the monomers (polymer building blocks) that make up RejeX to attach to the surface being treated and to crosslink into a crystal-clear, impervious film. It is important to allow RejeX to cure for 8-12 hours after the haze has been wiped off. If the coating is exposed to contaminants such as oil, fuel, soot, hard water, tree sap, cleaners, etc. before it has cured, the contaminants may interfere with or imbed in the protective film."
