Sort By
- gboppExplorer
BarabooBob wrote:
$3.50/gallon. Throw the old stuff away.
I think this is the best option. - If you run RV antifreeze thru a Water filter, it will remove the Pink. Still good, just does not have the color. But, I have Pink antifreeze at the shop more than 3 years old and is still pink. Doug
- BarabooBobExplorer III$3.50/gallon. Throw the old stuff away.
- ppineExplorer IIAntifreeze is cheap. Replace it and try some new.
- LwiddisExplorer III agree. Buy a new bottle.
- Monkeyman_and_LExplorerI'll go get new I think. Can't explain why the color change.
- haste_makerExplorer III have had some sitting outside for over two years and it's still pink, was the seal broke under the cap when you opened it? If so it may have been used & refilled with water.
- craig7hNomad III have had a bottle sitting around for over a year and its still pink. Option 1 call the company Option 2 go buy new stuff. Is the cost of good antifreeze worth the possible destruction freezing could do in your rig.
38,718 PostsLatest Activity: May 03, 2025
