Well I took the cover off the RV. Immediately I noticed where the cover has rubbed against the side front and back and it looks like someone took a brillo pad to the bumper area. I took it to CW in...
If it is a full body paint job, chances are that the cover has rubbed through the clear coat finish. This is something that can only be fixed by a repaint of that area and is NOT a simple spray on more clear coat type of repair. IF you have a fiberglass exterior coach with decals you may be able to buff or compound the area out to bring back the shine. This can be done by hand if you do not have a buffer.
