rookie_rv's avatar
rookie_rv
Any Benefits to 30amp to 50amp
Rookie RVer :C here!
Are there any benefits to plugging my 30amp (using an adapter of course) into a 50amp? When I have the option at campgrounds to plugging into either 30amp or 50amp I’ve been purposely plugging into 50amp with the belief it’s more stable.
  • I used to do it only because the 30A outlets were often worn out and loose.
  • Agree with rk911, the only real advantage is the 50a plug is usually in better shape. Another possible advantage would be if the 30a feed had a lower voltage level but you might not be able to get the other leg on the 50a with your adapter, so it would be a moot point
    not sure what you mean by 'stable'. when we had a 30-amp MH we would occasionally plug into the 50-amp hookup when/if the 30-amp receptacle had visible damage, was loose in the box, etc. IMO beyond that there is no practical difference. we have run into a small number of parks that forbid the practice of plugging into the 50-amp with an adapter. I'm sure there is a reason for that but I've never heard it.
