Hi Mark, I use a power washer on the roof of my 35-U! I use Simple Green straight 1.1, when I use the power washer I keep the stream of water off of all the roof seams. I also use a couple of bungee cords to tie the power washer down so it doesn't vibrate off the roof. If your awning or slide out awning toppers are extended out, when washing keep the power washer on the lowest setting or it will damage the awning. I wet everything down, fill the bucket half full, then use a bristle deck brush to scrub everything except the seams, then rinse. I've never used any wax or polish on my roof it's slippery enough up there!
