Ivylog wrote:
In those years the Dynasty gave the most bang for the buck. Not sure it's a 41' as most were 40 or 42. The early 03 LR slide only goes out 24" while later 03's go 34". Probably a 350 HP while a 04 will be 400. May have two ACs and a 10K generator while a 04 will have three and a 12.5K. May only have two slides while a 04 will have 3-4 slides. May not have AquaHot or Girrard awning while most 04's will have. My point is there was a lot of changes between 03 and 04 in the Dynasty line. A early 03 should go for less than $70K.
*I've owned mine for 10 years and see no reason why it will not go another 10-15. I like the solid handling of the RR10S chassis and I recently did 1900 miles in 48 hours as it's that easy to drive. I would look at the age of the tires and batteries although my engine batteries went 11 years and still tested good.
This coach does have the 24" slide in the living room which voids one of our wants (real hide a bed),it does have a 12,500 generator which purrs like a kitten, very little noise inside, not like the one in the 2000 Newmar I looked at last month. The seller says it has a 500 horse engine and the length he thought was 41' but I will need some more info. It has original tires at just 30K on the odometer, they will buy all new tires if I were to buy it. They had to replace the front piece that is in front of the generator and repaint the front end due to previous owner driving into a guard in front of the gas station islands. The outside is very clean and all seams looked good with no signs of needing re sealing. I looked the nada average up which is 134K and low resale value at I think 104K. They said they will be open to offers since he doesn't want it there through the winter. The owners son the the rv dealership bought it back I assuming from the bank with the front end damage and hope to make a little money, he never used it once. I dont see them going less than 100K and unfortunately thats going to be out of my price range without stretching ourselves too thin, and I cant do that at 57. The place I work for is uncertain all of a sudden, so I'll wait a little longer
