shawdowboss
Aug 01, 2017Explorer
The compressor is loud enough when running you really don't want it under the front seat. It's the same compressor used in air suspensions, and they are pretty loud and will run to keep the tank full unless you put a switch in to shut the compressor off when you are not wanting it to run.
I put in a Bolo Bad Boy air horn (120DB). IT's loud enough to get peoples attention by itself. I put it in parallel with a regular Bolo replacement horn, so a quick shot just runs the replacement and if you hold the horn down (>2sec), the air horn takes over quickly. Combined, they do make for an attention getter.
