fulltimin
Aug 16, 2017Nomad
I finally removed and replaced the rest of the bolts that hold the coach frame to the frame of the chassis. Yay....!!!
That means that all 12 have now been replaced.
Here are the front 4, and 3 of them I had to tack weld the washer to the floor joist, and then the bolt head to the washer, to hold it when I tightened the nut on the bottom, from under the coach.
And here are the rear 8 that were replaced. Only had 1 of these that I had to weld fast, because I couldn't reach top and bottom at the same time.
Inching my way toward being able to replace some of the aluminum sheeting on the bottom of the floor joists. Yee....Haw....!!!
38,705 PostsLatest Activity: Jan 26, 2025
