- Here you can see the difference between the thickness of the walnut that I am gluing to the plywood - (red arrow) - and the thickness of the face layer of the 1/2" plywood.
Cool, huh? Lol.
- And the beat goes on.... and the beat goes on....
With these glued up, out of 24 tops and bottoms, only 5 more need ot be glued. Wahoo!! - Here you can see on the right hand side, (the back of the drawers), I have shims to make sure the drawers are level at the front before I clamp them.
- Here are some more drawers glued up. On these, both the top of one drawer, and the bottom of the next now have walnut on them.
The only ones here with no walnut, is the top of the top drawer, and the bottom of the bottom drawer.
- I pulled out my Titebond 3 and an acid brush from Harbor Freight and began to glue more walnut onto the drawers tonight.
- At this point, I added a drawer on top for pressure across the top, and secured them with a few clamps, waiting for the glue to dry.
I should be able to do more than 3 at a time, but this is what I did tonight to get started. - I added glue to the top of 3 of the drawer fronts. Yes, I wiped off the excess before putting the walnut on there.
- I ended up with a bunch of thin pieces looking like this.....
You may ask, why did I not set the fence 1/32" from the saw blade and then not have to move the fence after each cut?
I do not like cutting strips that thin, between the saw blade and fence.
I have done it a few times, but I really don't feel all that comfortable doing it.
As such, I felt more comfortable this way, as the 1/32" piece would not be "trapped" between the blade and fence. - I then removed the walnut between the plywood and the fence.
Making sure the plywood would not move, I then moved the fence up against the plywood block.
I removed the plywood block, and then ran the piece of walnut through the saw again.
That gave me the thickness that I wanted for the drawers. - After cutting the walnut to width, without moving the fence, I did the following.
I wanted a piece of walnut that ended up about 1/32" thick. The thickness of my saw blade is about 1/8", so adding those 2 together, we end up with about 5/32".
I inserted a piece of 5/32" thick walnut, between the plywood block and the fence.
38,768 PostsLatest Activity: Nov 21, 2015
