Tvov wrote:
BennieH wrote:
"I wouldn't think that would be much of a problem. Diesel engines generally generate more heat than a gasoline engine because of the high compression."
Actually diesels run cooler in the engine compartment. That is why all ambulances are now diesel. There were a LOT of gas engine ambulances that had engine compartment fires in the late 90's and all the builders switched to diesels.
Interesting. I thought the switch was made because ambulances have become so large (F450 and F550 sometimes) and due to constant running / idling.
Constant idling is not good on a diesel.
