bobndot
Sep 29, 2020Explorer III
This subject is new to me. I am missing something here ?
During cold weather, between 0-32F, it would be necessary to preheat a Lithium battery before my solar panel starts to charge it. Correct ?
Therefore, if I have my rv stored or parked in my driveway for days or weeks, I can't just forget about it like I do using my AGM batteries, correct ?
Using lithium's , I too was thinking about using an insulated battery box and install a heat pad in order for my solar to start charging it. Therefore, I really need to leave the rv plugged in to shore power in order to heat the pads.
The only real advantage for me to use lithium is for summer use when I could drop below 50% while boondocking and not worry about charging them back up on warm days.
If that's the case, using my AGM's in the winter and lithium's in the summer seems to be a better option . Either that or look into the Si02 batts as suggested. Am I correct on my thinking ?
38,780 PostsLatest Activity: Aug 05, 2026
