BFL13
Oct 25, 2020Explorer II
VA-Apraisr wrote:
They sent a 60amp Lithium battery charger for generator/shore power and a Sterling power battery to battery DC charger for chassis battery/alternator charging while driving. It’s also a surge protector for overload surge back feed to alternator. Both designed for use with their battery. Put my trust in their knowledge and expertise and hoping for the best. So far so good ??. And the fishing sucks but beautiful weather on the island. Heavier winds coming which should help fishing ??
The Battleborn Sterling DC-DC on their site is 24-12, so how can you use that in a MH? Do you have a 24v engine battery?
What is the scenario for a surge from House to Engine side?
BTW, their 60 amp "Li battery charger" is just a PD converter set to single voltage (not three stage) at 14.6 ish (seen different values for 14.x on that) and the advice seems to be to disconnect it from the Li after the Li is charged up--ie. Do not float at 14.x for very long.
Or is that wrong and yours does drop to 13.6ish for floating?
Suggest confirm output of that PD converter is not over the Battleborn limit of ISTR 14.6. ISTR some of those "Li PDs" are at 14.8
Hope you can clarify how all that actually works, as this is new tech that many of us are trying to understand. Thanks.
38,783 PostsLatest Activity: Sep 09, 2026
