pnichols
May 16, 2018Explorer II
IAMICHABOD wrote:klutchdust wrote:pnichols wrote:
When the light comes on - how much gas is left MAY depend upon much you put into the tank the last time you filled it.
Our Ford E450 55 gallon tank will take about 5 gallons more after most station pumps stop. I can slowly trickle-fill after pump shut-off and get at least another 5 gallons into the tank whenever I fill up. I always try to do this so as to get more travel miles between refills and to ensure we have plenty of fuel supply margin for running the Onan generator should we decide to dry camp.
I have gotten 7 gallons in my tank using that method. It sure makes a difference.
My mechanic just loves people that do this,that means that eventually they will have to have their evaporation/charcoal canister replaced.
They are designed to capture vapor but when overfilling they get full of gas and fail,This will lead to a poorly running vehicle, higher emissions and eventually a costly repair bill.
I have three vehicles that I trickle-fill because their gas tanks are not full when gas pumps shut off ... they have been fine with this type of filling for years, as follows:
1. 1995 GMC 4X4 pickup that I have been getting ~4 more gallons into it after gas station fuel pump shutoff - for around 21 years.
2. 2002 Lexus sedan that I have been getting ~1.6 more gallons into it after gas station fuel pump shutoff - for around 13 years.
3. 2005 Itasca E450 Class C motorhome that I have been getting ~5 more gallons into it after gas station fuel pump shutoff - for around 12 years.
For me gassing up is an unfortunate necessary evil, so I want to do it no more often than necessary. I wish vehicles came with larger stock fuel tanks than they do.
The DW and myself together once built a Dodge B250 van into a camper van. It had about a 26 gallon stock gas tank. I installed an aftermarket steel 40 gallon auxiliary gas tank on it for a total gas capacity of around 66 gallons. Since it's 318 V8 got around 17-18 MPG on the open road, we didn't need to refuel on camping trips for over 1000 miles ... what a great feature that was!
Ford and Chevy are right on with their 55 gallon and 57 gallon, respectively, gas tanks on their cutaway van chassis used under U.S. Class C motorhomes ... that's a step in the right direction.
38,778 PostsLatest Activity: Jun 10, 2026
