bodyman7's avatar
bodyman7
Aqua Hot Problems
I have a 2013 Winnebego Tour. When the electric hot water switch is on you came put your hand under the hot water facet and the water is lukewarn but will not burn you, adding the Aqua hot helps a little but while taking a shower the water gets lukewarm but does not get hot even with the Aqua hot on. I had a certified Aqua Hot tech change the thermostat at the FMC Rally in Gillette but this did not help. Does anyone know what my problem may be. I'm headed back to Lazy Days in Florida for some warranty work in August but was hoping I could get this fixed before then....Thanks for any help yu can give.
  • Aqua/Hydro Hot has some of the best owners manuals found anywhere. Their 'troubleshooting' section will probably narrow down your problem and possibly lead to a solution you can perform yourself.
    YMMV
    Good luck.
