doubleG's avatar
doubleG
aqua hot started and quit
Hi All,
Started the aqua hot a week ago and all seemed well. Then yesterday,
water didn't seem hot. Turned off and turn back on. It seemed to turn on and after about 30 mins it cut off and won't start at all. Now looking back as well, don't know if it was only the blower or even if it ignited. I see a few places to start to look for, but has anyone had this and can tell me what to start with as far as looking at? Diesel above 1/4 tanks and do have plugged into 50amp. Did not from sitting chassis batts are low that won't start coach and have them on charger.
Going to get in unit today. It is tight getting everything apart and the reason maybe someoone has a point to start? 2007 Monaco Dynasty Queen IV. Thanks,
Dan
  • Clearly a great source for laughing, reading some comments by folks who surely have zero understanding how things work.
    My coach does have the Aqua Hot, yes it requires 12 VDC to operate even when your using the 120 VAC electric element.
    Yes they are not cheap, but sure are nice to have providing great heat without all the noise & fuss.
    Ya'll carry on with the humor, I love it.
    Dave M
  • "doubleG"......Get your battery issue resolved before you start tearing things apart. The Aqua Hot uses 12 volts to power it's system. Even though you're plugged in, power is coming from the batteries that are being charged.
  • Use the troubleshooting checklist and follow it...it will point you to the probable causes. aquahot.com troubleshooting for you ...
  • Thanks All,
    Have had low fluid before, but red light showed on panel. Will have to check sensor and maybe jumb to see if.
    Also, have tried to hit reset and to no avail. Does warm well water on electric to get us buy until fix.
    Thanks,
    Dan
  • Double G, there is also a reset button on the Aqua-Hot panel that you have to use the end of a paper clip to push it in.
    Does the water heat on electric?
    Good luck,
    MM.
