Well, Aqua Hot has a no heat by electric issue. Took the cover off and using the owner manual trouble shot the issue. A ground wire broken off the relay terminal. After trying to remove three othe...
Seems like A Hot is bad about sending the wrong part as you are not the first one on here to have that happen. What model A Hot do you have? I pity anyone with a MH that has to take it to a dealer to get most things worked on, even if the dealer is close by. Glad you got it fixed and now have a spare part. I carry lots of spares BUT I need to make a list of what and where I put them as this getting old... I'll leave it at that.
