sansouci2
Oct 12, 2017Explorer
Aqua Hot
I have a 2003 Monaco Exec 40 ft. The Aqua hot was not warming the living area or the bathroom, the bedroom was toasty warm. Took it in and they found one leaking pump out of 3 pumps. They replaced it ...
Mr.Mark wrote:gutfelt wrote:mtofell1 wrote:
I'm confused - I thought these were hot water pumped radiant systems but now I'm seeing comments about fans. Are there fans in each zone that blow air out of registers? I had been picturing in-floor radiant systems like I see in houses.
as doug has told you these are heat exchangers with 12V mini fans blowing air through the fins of the heat exchangers
the hot antifreeze is pumped though lines and through the heat exchangers
And, why would you have to repeat what Doug said? I think you have been here before.:p
MM.
